Hi Everyone,
In my drawings, I'd like to display a dimension as text with tolerance values like the image below.
1. If I use Hide Dimension Value in the text tab, it doesn't show the tolerance
2. If I use Override Displayed Value in the Precision and Tolerance tab, it doesn't allow non-numeric input.
Any thoughts?
Ilyas
Solved by Michiel.Valcke. Go to Solution.
Solved by YannickEnrico. Go to Solution.
Do a combination of overwrite dimension value and input a text in the text field like this
Edit: Just realised you might not want the numbers at all.
