Inventor Forum
Saving IDW to DWG(editable in autocad).
3 REPLIES 3
1315 Views, 3 Replies
I need to convert 2D drawings from Inventor(IDW) to Autocad(DWG) . Using "Task Scheduler" I can convert them automatically, but it turns into a none editable DWG drawing. The only way I know its to save as... one drawing at the time then I get a true editable DWG in Autocad model space.
3 REPLIES 3
In TS, do you use export function?
Using convert function you get inventor .dwg, if I remember correctly.
I'm having the same problem. I need to export the idw file as dwg and work with/edit it in AutoCad. But the export function doesn't work for me. I export the file as .dwg but I can't edit it in AutoCad.
You guys may need to select the cad version for export before 2007. Hope it help.
