I need to convert 2D drawings from Inventor(IDW) to Autocad(DWG) . Using "Task Scheduler" I can convert them automatically, but it turns into a none editable DWG drawing. The only way I know its to save as... one drawing at the time then I get a true editable DWG in Autocad model space.
I'm having the same problem. I need to export the idw file as dwg and work with/edit it in AutoCad. But the export function doesn't work for me. I export the file as .dwg but I can't edit it in AutoCad.
