Running Inventor projects from OneDrive
StewartFuchs
Message 1 of 9
StewartFuchs
I have a client who wants to keep their Inventor parts library and templates on OneDrive instead of on a server. Is there a way to point to the actual OneDrive cloud location rather than pointing to the synced version located on each users C drive?
Replies (8)
Message 2 of 9
bradeneuropeArthur
You can create a new project file (ipj) in a onedrive folder, like a normal project file.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
StewartFuchs
I've tried that. It works fine for single users. In fact, I occasionally do it when I work back and forth between my office and clients sites.  But it doesn't seem to work for multi users because the project points to synced folders on their individual workstations. Which is what they don't want.
Message 4 of 9
swalton
Isn't Vault designed for similar workflows?
If the users are outside the Company's firewall it gets a bit complex. Vault Gateway can help there.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 5 of 9
bradeneuropeArthur
You can use sharepoint for that!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 9
StewartFuchs
I agree that it gets complex. They are going to look into installing Vault. This is the best option IMO.
Message 7 of 9
johnsonshiue
Hi! I think you may want to map the OneDrive folder as a logical drive. It may work better with Inventor, because Inventor is a desktop based CAD tool. It assumes files are from logical drive locations. Please take a look at the following thread.
https://forums.autodesk.com/t5/inventor-forum/workgroup-search-paths-and-onedrive/td-p/9880944
Many thanks!
Software Test Engineer
Message 8 of 9
bradeneuropeArthur
As mentioned, sharepoint will do the trick.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 9
Ronald_King
Have you used the Legacy "shared Projects" within One-Drive to allow multiple users to use the shared Workgroup rather than a workspace??  What could possibly go wrong?
