Announcements
Announcements
We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Spiral Bevel Gear
Talayoe
Spiral Bevel Gear
Talayoe
Good day all,
I am redesigning a gearbox with a right angle gearset. The right angle set exists already and will not be remade, but I want to incorporate a representation of it in my model.
Being that we make gears, I familiar with most types, but not spiral bevel. I know inventor does this, but I do posses the information to properly replicate it using the bevel gear generator. As such, I have drawn the blank and want to cut/extrude the teeth around the pinion manually just for representation sake but I am unsure how to do this.
I have attached the dummy model. It is to scale and accurate so far as I can measure, just not certain how to draw and extrude a 3D tooth profile.
Tks!
-Randy
Inventor 2017 PDS
Alexander.Xu01
Hi Randy,
I tried to use coil feature to create the extrusion, I think its sufficient for representation purposes.
Hope this helps.
Alex
