Inventor Forum
Rubber Poured into mould around steel frame
5 REPLIES 5
MikeKovacik4928
239 Views, 5 Replies
Hi All
I have never tried this before. After I have created my steel assembly. How do I "pour" rubber into a mould around it, to get another assembly just consisting of the steel assembly plus the rubber around it as one other part.
Every single surface will be covered by rubber (polyurethane). A mould is made, the steel frame put into it, the polyurethane mixed and poured in, left to cool and harden, then cured in an oven.
Mike Kovacik
South Africa
Inventor Pro 2023
IQ_211_Rubber Mould around Steel Frame_001.jpgIQ_211_Rubber Mould around Steel Frame_002.jpg
5 REPLIES 5
I would derive your steel weldment into a new part then model the rubber around it.
Using Inventor 2022 on Windows 10
Ideas needing support: spur gear tooth profile, rack gears generator
How do I derive my steel weldment into a new part. Never done that before, what command?
blandb
in reply to: MikeKovacik4928
If you start a new part, Manage tab > Derive, then add the assembly as a single body. You can then use the Shell command and instead of removing material, use the outward direction and type whatever wall you want the rubber thickness to be. Now you can make a new assy of your rubber and your part together:
Shrinkwrap/simplify from the weldment itself as a single body does the same as deriving the part...Just another workflow
Autodesk Certified Professional
MikeKovacik4928
in reply to: blandb
That seems to work.
Regards
Mike K
Hi Mike, you can also use this method. Create the mould external shape and add to an assembly, then copy and combine.
https://www.youtube.com/watch?v=dvrMA15pj2o
James W
Inventor UX Designer
How to cut profiles into other parts that are too difficult to do with a simple cut. Can also be done with imported geometry.
