Inventor Forum
row height in BOM table
7 REPLIES 7
Message 1 of 8
nedeljko.sovljanski
397 Views, 7 Replies
Hi everyone,
Does somebody know how to calculate row height in BOM based on font style, font size, gaps,... ?
7 REPLIES 7
Message 2 of 8
You may find a quicker answer in the Customization forum.
They do a lot with BOMs using iLogic and VBA/VB.Net, so they would know all about that.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 3 of 8
What specifically are you trying to do?
Inventor basically handles row height in a parts list based on the text style you use and then has a "row gap" which gives top/bottom padding to each cell.
If you use a 2mm font and set row gap to 1 mm you will have a 4mm (2+1+1) tall row.
Message 4 of 8
I am trying to draw thicker border around some rows in BOM. I will check BOM properties. Thanks.
Message 5 of 8
I would think this work is best done in excel directly to the parts list /BOM export, The part list table has limited options for modifying the table borders like you would do in excel. You will likely be able to find a VBA macro to highlight a range based on range contents.
Have you a picture of where you wan the finished table to be and what it looks like?
Regards
Alan
Message 6 of 8
HI @A.Acheson , but after that I need to paste excel table in drawing, and I something changed, table will not be updated.
Message 7 of 8
Here is a few post on ideas about having this functionality implemented.
https://forums.autodesk.com/t5/inventor-ideas/add-parts-list-border-line-format-settings/idi-p/79090...
With marginal workarounds.
https://forums.autodesk.com/t5/inventor-forum/parts-list-on-drawing-line-weight-settings/td-p/105658...
Regards
Alan
Message 8 of 8
Depending on font name, row gap and text in part list cells, heights can vary and easiest way is: let Inventor to calculate and we will just read this values. The values could be found at:
DrawingDocument.Sheets(_number_).PartLists(_number_).PartListRows(_desiredRowNumber_).Height
Technology Administrators
