Hi everyone,
Does somebody know how to calculate row height in BOM based on font style, font size, gaps,... ?
Solved by nedeljko.sovljanski. Go to Solution.
You may find a quicker answer in the Customization forum.
They do a lot with BOMs using iLogic and VBA/VB.Net, so they would know all about that.
What specifically are you trying to do?
Inventor basically handles row height in a parts list based on the text style you use and then has a "row gap" which gives top/bottom padding to each cell.
If you use a 2mm font and set row gap to 1 mm you will have a 4mm (2+1+1) tall row.
I am trying to draw thicker border around some rows in BOM. I will check BOM properties. Thanks.
I would think this work is best done in excel directly to the parts list /BOM export, The part list table has limited options for modifying the table borders like you would do in excel. You will likely be able to find a VBA macro to highlight a range based on range contents.
Have you a picture of where you wan the finished table to be and what it looks like?
HI @A.Acheson , but after that I need to paste excel table in drawing, and I something changed, table will not be updated.
Here is a few post on ideas about having this functionality implemented.
With marginal workarounds.
Depending on font name, row gap and text in part list cells, heights can vary and easiest way is: let Inventor to calculate and we will just read this values. The values could be found at:
DrawingDocument.Sheets(_number_).PartLists(_number_).PartListRows(_desiredRowNumber_).Height
