Is there some kind of constrain that just makes 1 part fix relative to another part?
Solved by bradeneuropeArthur. Go to Solution.
Use "Joint" with "Rigid"
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Hi! Arthur is absolutely right. Rigid joint is the piggyback joint. The part will be attached to the other part and move along with it.
Many thanks!
