Rename issue
Rename issue
spl1970
Rename issue
spl1970
Hopefully this is easy enough for someone but it's driving me round the bend.
I've renamed a part in Vault but when I open it the old name appears in the assembly browser and the part when I open it in Inventor.
Anyone have any idea why this is?
Accepted solutions (3)
-niels-
Slow double click on the name, or click the name and hit F2, then delete the name and hit ENTER.
Does that fix it?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
bradeneuropeArthur
The "Display Name" can be different then the "File  Name" in the Browser.
Also it is possible that the "Part Number" is shown in the browser and not the filename.
Have you updated the Part Number on Rename in Vault?
There is also an rename "Browser Nodes" in the "Assembly Tools" in the Inventor Ribbon!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bhavik4244
@spl1970
Firstly, make sure you have chosen the "Update Part Number" as "Yes" while renaming it in the vault.
e.g.
Secondly,  you may rename it as you wish from "Rename Browser nodes"
I hope this would solve your issue.
Bhavik Suthar
sanelP52
I have a question !
When I rename this node , where is that text saved in background, what is the name of that text parameter.
So when i click rename browser nodes, if I choose part nubmer, it works , if I choose default, it uses some old numbers, that have been changed before.
So when i choose default in Rename browser nodes, where is that default parameter placed..
spl1970
Is this a content centre part? If it is it's in the family table and you need to change it there.
sanelP52
Ok in this picture it is from CC, but I ask for normal parts , that occurs per exapmle 10 times in 1 assy, and I edit those browser nodes , and give a different name to those instances, and questions is where is that new node text saved, what is that text parameter called , where it is located.
