Quantities next to Baloons...sigh
chuck.bardsley
Message 1 of 13
chuck.bardsley
How does everyone tackle the issue of placing Qty's next to balloons?  Please post your screenshots.
I don't like the split balloon option.  My image shows a few sketch symbols that I've created which allows me to depict quantities.
I can only search the forums for so long.  I've found similar questions going back over 14 years. Sad that Autodesk hasn't solved this yet.
Right side shows sketch symbols usedRight side shows sketch symbols used
Chuck B.
Replies (12)
Message 2 of 13
SBix26
I'm guessing this is not high on the list to be "solved".  I've never seen a drawing annotated this way or used anything like this.  Are there ideas posted in the Inventor Ideas forum that address this?  If you don't find any there, create one yourself.  Whatever you find, post a link to it in this topic so people can vote for it.
Sam B
Inventor Pro 2023.2.1 | Windows 10 Home 21H2
Message 3 of 13
cadman777
I just use a leader and delete the leader line.
It attaches all around the balloon.
All values are manually entered.
There is nothing automatic or parametric about what I do.
This subject has been discussed recently in a number of variations.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 4 of 13
-niels-
I've always been under the belief that balloons are just indicators and their quantities are to be found in the parts list.
I usually balloon identical parts when i want to indicate that they are the same.
That said, i probably would use the "attach text to leader" option to add quantity if i really had to.
(i use this now to indicate profile sizes that can't be directly found in our parts lists)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 5 of 13
ampster40
cadman, you do not need to delete the leader.
Select a quadrant of the balloon to attached the leader text to and then hit Enter to begin entering text.  Click finish when done.  It will not add a leader to the text but instead simply display the leader text next to the balloon.
Take note however depending on which side of the balloon you want the leader text to be attached to and add a space within the text window to space the text away from the balloon.
Message 6 of 13
Frederick_Law
I just use balloon style.
I mostly use this on frame.  Showing member size and count.
Message 7 of 13
snguyenSWVMS
I like to use the balloon with item on the top and qty. in the bottom.
I want to know if there is a way to add an (X) at the end of the QTY.
Message 8 of 13
B_MARPET
THIS IS MY METHOD TOO. EASY AND CLEAN.
Message 9 of 13
B_MARPET
THE MAJOR PROBLEM WITH THIS METHOD IS THE QTY ISN'T VERY "STICKY".
(IF YOU MOVE THE BALLOON OR STRING OF BALLOONS THE QTY (WHICH IS REALLY JUST LEADER TEXT)
WON'T MOVE WITH THE BALLOON OR STRING OF BALLOONS.
Message 10 of 13
dan_inv09
Are you sure that you are using leader text?
The leader text should move with the item (in this case the balloon) that it is attached to.
Are you just pointing your leader out in space somewhere in the vicinity of the balloon?
somewhere between those points (all along the top and down the side, across the bottom and along the other side) you will see a little symbol when you are attaching to the balloon [my screenshot tools are not letting me capture it so I have faked it in paint]
at the midpoint (like that top balloon)
at the corners (like that bottom balloon)
Message 11 of 13
dan_inv09
Now, I'm not exactly sure how you make a balloon symbol ...
okay, my quick attempt looks like it just assumes it's a split balloon and slops your sketched symbol on top of it.
(I thought you could make a circle and tell it to put the item number in there then put an x and tell it to put the quantity next to that.)
Maybe we'll get lucky and someone who has worked with User-Defined Symbols for balloons will happen along and show us how to do it. Cross you fingers.
Message 12 of 13
snguyenSWVMS
There is a way to add (QTY.) to balloon but I use it for long time and I hope Autodesk come up an automated to incorporated into the balloon command like Solid Work doing for long time.
The way I use to do is design symbol in drawing template link the balloon qty. in the text after insert the balloon then insert the symbol it snap around the 4 point of the balloon circle.
It is an extra step to do.
I hope Autodesk will add this to balloon step turn on the qty. or not turn.
Message 13 of 13
B_MARPET
THANK YOU FOR THE SUGGESTION.
WOULD I HAVE TO MAKE ONE FOR EACH QTY (2), (3), (5), ETC?
(NOT THAT IT'S OFTEN OTHER THAN (2))
