Bugs with frame lengths - Inventor Pro 2025
modelinEGJXB
modelinEGJXB
Hello everyone,
I'm having bugs with updating frame lengths.
I have a sketch from which I created a frame.
I then positioned clamps and adjusted my frames in the assembly section.
After that, I modified my sketch again and the update no longer works...
So I have to delete my length adjustment and redo it to get the correct length.
Is there a way to make this update work correctly?
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Thank you in advance and have a nice day!
@modelinEGJXB Your posts title was modified to include the product & version - CGBenner
johnsonshiue
Hi! I vaguely remember this was a known bug, which had been fixed in one of the 2025 updates. Please install 2025.3.1 update and retry the workflow.
Many thanks!
Software Test Engineer
CGBenner
@modelinEGJXB
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
modelinEGJXB
I installed update 2025.3.1, but it didn't resolve my issue.
As I am short on time, I manually modified each length in the sketch (-10mm for example), updated the assembly, deleted the previous modification (+10mm), and returned to the assembly. After that, the frame name matched the actual length of the frame.
It is likely that Inventor version 2026 has resolved this issue, but I am unable to try it. I must remain on version 2025.
Have a nice day!
johnsonshiue
Hi! If possible, please share the Inventor files in zip with me directly at [email protected]. I can follow up with the project team to understand the issue better.
Many thanks!
modelinEGJXB
Unfortunately, I can't share this file with you, and I can't reproduce it on another assembly...
If I manage to do so, I'll be sure to send it to you.
Have a nice day !
