Tube and pipe Routes name marked in red.
Malenki
Message 1 of 11
Malenki
For some time, I see that one of visible in browser "Tube and pipe Routes" name is in red. What means red color in this place? "Help" this does not explain.
2.
This same parts, insert using Content Center librry (marked in yelow)... but different iconsSmiley Surprised. Why?
Do somebody help me?
Thanks.
_______________________________________________________
Windows 10 64B + Product Design Collection 2021+ASM 2018
1. HP Z2 Tower G4: Intel Core i7-8700K [email protected] + Quadro P2000
2. GIGABYTE EX58-UD5: Intel Core i7 920 (2.66GHz to 3.6GHz) + Quadro FX4000
Replies (10)
Message 2 of 11
Mark.Lancaster
For the pipe run that is in red, I think that means there's something wrong with it.   Have you expanded it and check to see if everything is okay.
For the change in the content center icon..  Did you copy and paste that given component in your assembly?  If you did that is normal...  When you have the routed system add-in loaded and place tube&pipe components in your assembly, the bluish pipe tee is the standard icon that is shown for those components.   However if you copy and paste that same component in your assembly, then it shows the standard content center icon.
Mark Lancaster
Message 3 of 11
Malenki
At first I thought so too. But then warning icons are used, similar to those below. It is no other signs that something is not working properly!
2.
Yes. But than I deleted one and I inserted second time - normaly - from ContentCenter. Icon of this part remained unchanged.
Message 4 of 11
salariua
I normally ignore it Smiley Frustrated
Most of the time I get that when doing more than a segment inside the route or any other , unrecommended procedures. I see it more as a warning for when I am "bending the rules" with quick cheats.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 5 of 11
smokes2998
Hi Don't ignore these warnings !!!
From experience it usually a a missing radius in the route  or you have  a two lines not intersecting.
Message 6 of 11
salariua
Two lines not intersecting is EXACTLY what I want when doing branches in a route.
Adrian S.
blog.ads-sol.com
Message 7 of 11
smokes2998
How are you branching the route? because the route if using tube mode is considered  a single sweep if the line don't inster sect it will create two tube parts this is bad practice as it a pain to manage in the vualt. If you are branching a route in pipe mode the branches need to intersect to fit a t piece in from the library.
Message 8 of 11
salariua
I have no problem managing this and don't understand why is bad practice. Can you share some of your problems?
Branching is not allowed so connecting nodes (intersecting with coincident constraint) is not possible. Other workarounds are possible. Use construction lines or coincide the node with other line segments rather than nodes.
Separate route segments will become separate pipes even in tubing with bends. I tend to do all branches (of same size as the main segment) in the route.
Each to its own but it’s easier to modify and maintain this way. Here’s how I do branches:
http://blog.ads-sol.com/2015/04/tee-branch-and-route-editing.html
Adrian S.
blog.ads-sol.com
Message 9 of 11
smokes2998
Hi
If you are routing tubes and you want to get the bend co-ordinates for the tubes for the bending machine it gets a bit confusing which bend co-ordinates you require for which tube of of the route.If you have two or more tubes in the route. I also apply the one route per a tube rule to find dangling sketch lines. I also goup the routes into appropiate groups so it is easier to manage and find parts.
I have to route maybe 150 plus tubes in an assembly and draft up and dimension and assign a part number for each route tube this is the best way to manage it.
It also helps when copy designing routes into another assembly so you can reuse the routes and drawings and part numbers. it also stops the issue of creating unlinked or extrenaous parts in the vault.
it also helps when you have a guy based india doing the drafting and pulling the data from the global vault.
With pipes you just cut straight lenghts so it is not so bad
Message 10 of 11
salariua
@smokes2998, keep comming back to your post and read it out. I must say we don't use a bending machine and it's very rare that we send 3d models for fabrication. Drawings, fitted on site and then update the model to AS BUILT. Nonetheless I will try and keep in mind your remarks.
I can't use branches enough, in fact I have managed to connect 3 nodes for a while now and from all the tests it seems to be a viable solution (better, faster, easyer to use, and with less errors).
Like I said, each to it's own, one size won't fit all.
Adrian S.
blog.ads-sol.com
Message 11 of 11
favdic
Sometimes during the preliminary stage, I was trying to force the hose length using the "Hose Length" button.
After going back and relaxing things under this command, the route name turned back to black.
It felt as if Inventor couldn't reconcile what I drew and what I was trying to force on.
