Project Cutting Edge Redefine
bradeneuropeArthur
Mentor Mentor
Message 1 of 11
bradeneuropeArthur
Is there a possibility to Redefine the "Project Cutting Edge" Within the Inventor Sketch environment.
For example I have created a sketch based on invisible geometry in the inventor part.
Now the geometry will not be available in the sketch using the "Project Cutting Edge".
Afterwards/later that day I would  like to have also the invisible geometry available in the sketch.
I make the geometry visible and now i would like to update the "Project Cutting Edge" definition and add the now visible geometry. The only option is to create a new "Project Cutting Edge" but this adds also a new feature to the sketch.
I appreciate a comment or response
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (10)
Message 2 of 11
admaiora
Yes. You can.
You don't have to redifine the Project comand, but the Sketch (just re-choosing the same plane)
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 11
bradeneuropeArthur
Thanks for the response.
But when the second solid is extruded as surface this doesn't work, or am I missing something?
Do you have a solution for this too?
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 11
admaiora
Sorry, you didn't mention that we were speaking about surfaces
Admaiora
Message 5 of 11
admaiora
Just delete the projected feature and redo it again. Quite quick
Admaiora
Message 6 of 11
bradeneuropeArthur
Thanks, but that will be no option for me because I use the projected already.
Maybe this is something for the Idea station.
Do you have further good ideas?
Thanks for the help.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 11
johnsonshiue
Hi! Is it because the surface was created after the projected sketch?
Many thanks!
Software Test Engineer
Message 8 of 11
bradeneuropeArthur
Hi @johnsonshiue
No it was already there, but it was set Invisible!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 11
admaiora
I don't understand where is the problem in adding a Project Cut Edges feature.
Admaiora
Message 10 of 11
bradeneuropeArthur
Hi @admaiora
Every time the tree becomes a new feature and that is unnecessary.
With an update method this would be possible that the Project Cut Edges1 will be updated.
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 11
bradeneuropeArthur
Thanks for the answers.
Any other ideas!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
