tracing PDF into inventor
Message 1 of 9
I had a drawing sent to me deliberately with missing dimesion. Is there any way to make a most precise estimation by tracing the pdf file? I’ve attach the file here.
should i trace it in autocad instead? Though i would very much prefer to do so in inventor
Replies (8)
Message 2 of 9
damian.lewczyk
Autodesk Support
Autodesk Support
You can create picture from this PDF and insert it to part and scale it by using line and dimension tool.
Here you can find recorded solution:
Damian Lewczyk
Technical Support Specialist
Message 3 of 9
JDMather
Buat kedalam gambar >>Make into pictures...
Message 4 of 9
johnsonshiue
Hi! I thought you could measure in PDF. Also, what is the reason why dimensions were not given? Without dimensions, how do you recreate the part? Or, you are not supposed to know the dimensions?
Many thanks!
Software Test Engineer
Message 5 of 9
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 6 of 9
cadman777
Here's how I handle these, esp. when they have spline type curves:
1. Export the pdf into a pixel file
2. Bring the pixel file into a 'paint' program, convert it to VECTOR format, and export as dwg or dxf
3. Import that dwg/dxf file into an Inventor sketch
4. Make sure it's scaled correctly
5. Use Inventor sketch tools to 'scrub' your SKETCH.
You know the rest of it ...
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 7 of 9
mikejones
Autocad mechanical will import a pdf file and convert it into dwg which you can then bring straight into an Inventor sketch to reuse.
Unless the pdf drawing is an image as it is in this case. 😞
Mike
Autodesk Certified Professional
Message 8 of 9
Mark.Lancaster
Another option..
Even AutoCAD (vanilla) can convert PDF to DWG and then use the ANYCAD interface and project DWG geometry in your part file.
Also keep in mind the PDF you use to be converted to a DWG in AutoCAD products must not be scanned or an older PDF version/format.
Mark Lancaster
Message 9 of 9
cadman777
Which is why I said it like I did, b/c it covers all the bases, for all the versions ...
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
