Project Cutting Edge Redefine
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a possibility to Redefine the "Project Cutting Edge" Within the Inventor Sketch environment.
For example I have created a sketch based on invisible geometry in the inventor part.
Now the geometry will not be available in the sketch using the "Project Cutting Edge".
Afterwards/later that day I would like to have also the invisible geometry available in the sketch.
I make the geometry visible and now i would like to update the "Project Cutting Edge" definition and add the now visible geometry. The only option is to create a new "Project Cutting Edge" but this adds also a new feature to the sketch.
I appreciate a comment or response
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
