Pipe Break Appearance in IDW
MikeKovacik4928
Advisor Advisor
Message 1 of 12
MikeKovacik4928
Hi All Inventor Users
How do you all deal with pipe break appearance in IDW.
Personally
1. I either create a separate extra model and model the pipe break
    specifically for showing in the idw.
2. I do a crop in the idw view, maike the crop line invisible
    and then sketch the pipe break. If necessary I will do it on both sides
The view break command gives 2 options, neither of which apply to circular extruded shapes like pipes
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (11)
Message 2 of 12
Xun.Zhang
Hi @MikeKovacik4928,
I think this could be a new idea for ideastation to gathering support. before that, I think Drawing sketch symbol might a good choice. For example, define a symbol library and create the pipe breaks and then insert to the place you want.
Hope it helps!
Xun
Message 3 of 12
swalton
Xun,
This functionality request has been posted to the Ideas board for almost 5 years.
https://forums.autodesk.com/t5/inventor-ideas/s-shaped-broken-view-for-shafts/idi-p/3793222
Also:
https://forums.autodesk.com/t5/inventor-ideas/pipe-section/idi-p/5246795
There are 323 votes between the two posts.  How many more are required to actually get this implemented?
Steve Walton
Inventor 2025
Vault Professional 2025
Message 4 of 12
jletcher
Needs 7 years and you have to hold your breath and one eye close with toes up in the air..
Message 5 of 12
kelly.young
Autodesk Support
Autodesk Support
@MikeKovacik4928 thanks for posting the good image, would you mind adding it the the bottom of the two ideas shared?
I went and added two more votes.
Keeping the idea active and voted on is the best way to draw attention and get it implemented.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 6 of 12
MikeKovacik4928
Thanks Kelly
I have added my image and my votes to those 2 ideas
Mike
Message 7 of 12
MikeKovacik4928
Autodesk,
I got this message from Autodesk on a no reply address
I got the answer, not the one I needed though!
It is not possible in the current versions, but 2 ideas with lots of votes have already been submitted years ago and not implemented.
Not possibe to mark as an accepted solution, because there isn't one.
This was more a discussion, rather than a question requiring an answer, so this email is actually not applicable in this case,
which is why in these cases I ignore them.
Mike Kovacik
Message 8 of 12
Xun.Zhang
Hi @swalton,
Sorry for late response, checked with idea status, it seems was tracked already. There is a process to escalate the priority, so please stay tuned.
Thanks!
Xun
Message 9 of 12
Hi Xun Z,
Do you know if this modification can be done through the API coding? I'm working on this kind of piping drawings and I need to have the END PIPE symbol instead of the straight break line symbol.
Thanks in advance,
Sam
Message 10 of 12
lnsn
It´s been a few years now since this discussion started... Is there any news on the pipe-cut feature discussed above?
Message 11 of 12
CGBenner
@dan_szymanski this one seems to have been on a roller coaster ride in the Ideas for quite some time.  Can we get the Community an update on this one?
@lnsn Thank you for resurfacing this idea.
Chris Benner
Message 12 of 12
dan_szymanski
Hi everyone,
No real update to provide as this request is not currently in our near term plans for consideration. The Idea for it can be viewed here: 'S' shaped broken view for shafts and it currently resides within the Top 20 non-implemented Ideas on the board. That is all I can share at this time.
Dan Szymanski
Sr. Product Manager
