Since when it is not possible anymore to add a partlist to a drawing that has no drawing views.
What I can remember is that it was possible in earlier releases to add only a partlist to a drawing without model views.
The button has been dis-abled!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Solved by bradeneuropeArthur. Go to Solution.
2022.2 also!
Arthur Knoors
Oops.....
Found out what it issue was!
The drawing file was deferred update!
Arthur Knoors
