Inventor Forum
Partlist Add To Empty Drawing impossible
3 REPLIES 3
bradeneuropeArthur
396 Views, 3 Replies
Since when it is not possible anymore to add a partlist to a drawing that has no drawing views.
What I can remember is that it was possible in earlier releases to add only a partlist to a drawing without model views.
The button has been dis-abled!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Labels (1)
  • t
3 REPLIES 3
SBix26
in reply to: bradeneuropeArthur
You left out one crucial detail: what version of Inventor are you using, and what updates have been applied to it?
I just tried this on Inventor 2022.2, and it works as expected.
Sam B
Inventor Pro 2022.2 | Windows 10 Home 21H1
LinkedIn
bradeneuropeArthur
in reply to: SBix26
2022.2 also!
Arthur Knoors
Oops.....
Found out what it issue was!
The drawing file was deferred update!
Arthur Knoors
