Inventor Forum
No "Stress analysis simulation" menu in inventor 2018
8 REPLIES 8
Message 1 of 9
1036 Views, 8 Replies
I use the Inventor Professional 2018 but was not able to find "Stress analysis simulation" tab/bottom/menu anywhere in my software, in Add-ins shows "Simulation: Stress Analysis:  Automatic/Loaded" but can not find it anywhere to use it
8 REPLIES 8
Message 2 of 9
Binga
Hello.
Could you share an image of your screen?
Do you use the Professional version?
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Message 3 of 9
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Does it actually say Inventor or Inventor Professional in the title bar of the application?
Mark Lancaster
Message 4 of 9
in reply to: Mark.Lancaster
Hi Mark,
The title bar shows "Autodesk Inventor 2018", but License page Shows "Autodesk Inventor Professional 2018", please check attached Screen Shot
Salar
Message 5 of 9
in reply to: Binga
Hi Binga,
I attached a screen shot from my inventor, The title bar shows "Autodesk Inventor 2018", but License page Shows "Autodesk Inventor Professional 2018",
Thanks for your help,
Salar
Message 6 of 9
Mark.Lancaster
@Anonymous
There's nothing attached...  Did you reply via email?  If you did, don't..  Return to the forum and reply directly there.   Anyhow when you installed you select to install Inventor and not Inventor Pro.  Meaning there's an option there.  At this point you will have to uninstall and reinstall and make sure to select Inventor Pro in the installation steps.
Mark Lancaster
Message 7 of 9
in reply to: Binga
It looks like it does not sent the attachments via the email, Title bar says Inventor 2018, License Page is Inventor Professional 2018
Message 8 of 9
Binga
You will need to do what @Mark.Lancaster said.
Reinstall, and dont forget to select Inventor Professional.
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Message 9 of 9
in reply to: Binga
Thank you, I will try that and give you an update.
Salar
