I use the Inventor Professional 2018 but was not able to find "Stress analysis simulation" tab/bottom/menu anywhere in my software, in Add-ins shows "Simulation: Stress Analysis: Automatic/Loaded" but can not find it anywhere to use it
Solved by Binga. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
Hello.
Could you share an image of your screen?
Do you use the Professional version?
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Hello.
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
@Anonymous
Welcome to the Autodesk User's Community..
Does it actually say Inventor or Inventor Professional in the title bar of the application?
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Mark Lancaster
@Anonymous
There's nothing attached... Did you reply via email? If you did, don't.. Return to the forum and reply directly there. Anyhow when you installed you select to install Inventor and not Inventor Pro. Meaning there's an option there. At this point you will have to uninstall and reinstall and make sure to select Inventor Pro in the installation steps.
Mark Lancaster
@Anonymous
Mark Lancaster
It looks like it does not sent the attachments via the email, Title bar says Inventor 2018, License Page is Inventor Professional 2018
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
