Dimensions not appearing on drawing.
aky
Message 1 of 8
aky
Hello
I use Inventor Professional 2019.
Inventor dwg stopped showing dimensions... Old drawings created with the same template works fine.
But I cannot create new drawings and add dimensions.
I can't seem to find why... Please help!
Thank you
Replies (7)
Message 2 of 8
Cadmanto
Those are dangling dimensions which means they have lost their connection to those points on the model.
What changed in the model?  Is this model an ipart?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
Sergio.D.Suárez
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 4 of 8
aky
These are newly added dimensions..
Message 5 of 8
aky
Dimension layer is definitely on.
I can see the dimension lines, they just say all values are "0.0". It's like inventor can't measure the length.
But in the part, I can measure them just fine. It's just when I create an inventor dwg, Dimension doesn't work.
Message 6 of 8
aky
Hole/Tap Dimensions show up just fine.
All Linear Dimensions show up as 0.0
Message 7 of 8
Cadmanto
Is this an imported model or did you create it from scratch?
Does this thread speak to anything you are experiencing?
https://forums.autodesk.com/t5/inventor-forum/idw-model-shows-grey-lines-and-i-cannot-pull-dimension...
Can you post your model?
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 8 of 8
aky
I created it from scratch. I couldn't find the issue and inventor kept crashing so I re-installed inventor and it seems to work okay now.
Thank you.
