No Hatch lines when I use Half Section View Under View Tab in Inventor Part Mode
Gurpreet.Badwall
Gurpreet.Badwall
Hi Inventor Experts,
I am not sure if this is the case with Inventor. When I use Half Section View command under View Tab in Part Mode, Inventor is not showing the Section Hatch Lines. Please have a look on the attached Inventor Part File and  Screenshots. It does show the Half Section View but without the Hatch Lines.
NOTE: Just letting you know , I am not talking about the Half Section View in Drawing Mode.
Inventor Version Used: Inventor Professional 2021.3.1
Regards
Gurpreet
bradeneuropeArthur
That is normal behavior!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Gurpreet.Badwall
@bradeneuropeArthur  Thanks a lot Dear for your quick response.
I am also Fusion 360 user  and its showing the Hatch Line in Part Mode when I use the Half Section View command.
bradeneuropeArthur
Would be a good thing for the Idea Station, I would vote it!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
johnsonshiue
Hi! Do you want to see the 2D hatch pattern in 3D model? I don't think it is supported. The closest thing I can think of is to create shaded section view in the drawing.
Many thanks!
Software Test Engineer
Gurpreet.Badwall
@johnsonshiue Thanks a lot for your reply. Just letting you know I am also a Fusion 360 user and it does offer the Hatch Lines in Part Mode when I use the Half section view.
Note: I  already have hatch lines when I create the Section view in Drawing mode in Inventor.
