Inventor Autodesk Vault Server
matthewcibulka
Message 1 of 8
matthewcibulka
I am not sure that the "Autodesk Vault Server" libraries are "Not available," as shown below. Did something go wrong when installing 2020? Or do you have any other suggestions?
Replies (7)
Message 2 of 8
bradeneuropeArthur
Seems that they have been forgotten to migrate with Vault.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
matthewcibulka
Is there anyway to recover them to Autodesk Vault Server?
Message 4 of 8
bradeneuropeArthur
you need to do it again I think!
Maybe @johnsonshiue can confirm this too?
I have had the same and in 2018 of Vault.
I have added these CC libraries afterwards from desktop to Vault CC.
That will I think the easiest way!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
matthewcibulka
Sorry, I'm relatively new to this and I'm not sure how to get these files back on the vault server
Message 6 of 8
Chancellor.Kurre
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-...
Also you might try having your posts named something different, I see you have a few that are similarly named 🙂
Message 7 of 8
Chancellor.Kurre
Here's some more info, there are links in there with more articles on configuring CC with Vault
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
Message 8 of 8
bradeneuropeArthur
I have a special trick.
Using the installation files of inventor.
I need to search for the documentation first.
I will inform you later.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
