We are using 2022.2.2.
We are evaluating ways that we can incorporate Model States into our current workflows.
Is the Model State title exposed as a property (I can't seem to find it anywhere). We have different model states for an assembly represented by a single part number (they are just assembled in a different order). I was hoping to just use a leader linked to a model state property to differentiate on our drawing. I suspect it was not made available.
Hi Cory,
Active Model State for a given instance is available as a BOM property, not as an iProperty. It is accessible in BOM, PartsList, and Balloon.
Many thanks!
Hi Cory,
I agree with you. I don't think this is a solution. I did not mark it as such. I just explained how it worked at the moment. To get the Model State name on iProperties, there are actually a few ways to do that implicitly in the meantime. For example, you may add a custom iProperty named MS in your template or any file with pre-existing Model States. Then create an iLogic rule to populate the name to iProperty on a per member basis. Or, edit the Model States table in Excel and link the Model State name to the custom iProperty column.
Many thanks!
Hi Cory,
Regarding the ability to select component (sub or individual part) in a leader text, it is on our radar. You may want to sign in to Inventor Feedback Community to try it on the latest internal build.
Many thanks!
Hi @corym
Long time no see. How are you doing? I didnt recognize you from your profile picture :).
Its interesting and quite a pity that we dont expose any model representation name in a drawing. In fact we never did this for view-reps or lods either. With model states, the need has become a lot more visible. We discussed adding model state name to atleast the view label in a drawing so that one could see on the sheet what the view represented. I think we just couldn't get to it given the other priorities and there always seems to be some workaround (see the browser or edit the view).
I think you can achieve the same thing with custom iproperties but its painful like you said and probably not scalable and besides leader text doesnt allow custom iprops (i am still scratching my head over this one).
I am sure you may have tried it already, but if you have not, I created a vba program to collect model states information and add them to custom iprops. If you already have, others can still take a look at it.
The program traverses an assembly and sub-assembly and parts and gets the model state names and adds them to the custom properties for that document. Trust me, it was not as simple as I thought (maybe because vba is not my native language 😞 )
In this example, I have
Top.iam
+ Sub.iam
+ Part.iam
Each file contains 3 model states each.
I then created a drawing with 3 views - each view of a different model state. Then, I ran my vba program which traverses the assembly, collects all model state names and automatically creates custom iproperties for each document. Then, I modifed the view label to include the model state name.
To run this program:
1. Open Top.iam
2. VBA Macros/Editor
3. Run CustomIProps
4. Open Top.idw
See the view label showing the model state name.
If you edit the view label, you will see that I have inserted the model state name using custom iprops. Still, i could not expose sub-assy/part custom props in the view label.
-shiva
