Make part from solid with feature recognition
vkulikajevas
Message 1 of 16
vkulikajevas
Is it possible in Inventor to export a solid body with a pattern feature recognition?
In this example I made a part-Layout with a Body "Solid01". Then I have made a Part using body "Solid01" (Make Part function).
Exported "Solid01" has not feature recognition...
Replies (15)
Message 2 of 16
JDMather
If I follow your description :
You have successfully run Feature Recognition - including Pattern, but now cannot select that pattern when placing components in assembly.
Did you switch to model view?
Can you zip and Attach your assembly here?
I just read this again and it sounds like you did not run Feature Recognition.
Without a Pattern Feature there is no Pattern Feature to read in placing the component.
Message 3 of 16
Mark.Lancaster
@vkulikajevas
Exporting to other CAD packages, makes the solid "dumb" and all history and parametric values are lost.
Mark Lancaster
Message 4 of 16
vkulikajevas
@JDMather
Thank you for response.
Adding the inventor files in a rar folder (Inventor 2017).
I need actually to pattern solid according to the hole Pattern (pattern is not always rectangular).
@Mark.Lancaster
Thank you for reply. Maybe you could suggest a workaround this problem? For Derive somehow to retain the features?
Message 5 of 16
JDMather
I specifically requested zip file.
I do not have extraneous software (rar extractor) installed on my clean Inventor machine.  Only access to Windows OS zip extraction.
Message 6 of 16
vkulikajevas
@JDMather ,
Somehow Autodesk forum does not permit attach of zip files here.
Message 7 of 16
SBix26
Here are the files (2017), zipped...
Sam B
Inventor Pro 2020.1.1 | Windows 7 SP1
LinkedIn
Message 8 of 16
JDMather
This is a Derived Component, not an exported solid body?
Message 9 of 16
WHolzwarth
If this isn't just a simplified sample, I don't see any benefit in using the derived part instead of the original IPT.
With the original file, assembly patterns along a feature in part environment can be done.
Don't trust too much in Feature Recognition. This only succeeds with rather simple geometries.
Walter Holzwarth
Message 10 of 16
vkulikajevas
Dear @WHolzwarth ,
I have made a simplified part only for this example. In real situation I have a multibody layout with many features, which I need to export to Assembly. And this assembly does not recognize patterned features (which I want to find a way to be recognizable. I don't need to recreate the body, I need to use the original body features from the layout. Tried to be specific and as short as possible in the provided example. @Mark.Lancaster  said already that this might not be possible. Maybe there is some workaround this problem...
Message 11 of 16
JDMather
It should be pretty easy to add pattern of Workpoints to the Derived Component.
Message 12 of 16
SBix26
This is one of the few real problems with using the master part method of Inventor design, that feature patterns do not carry through to derived parts.
A quick search in the Inventor Ideas forum produced two similar ideas (which need to be combined) to which all reading this should lend their vote:
Recognise feature pattern in derived part when creating assembly pattern
feature/pattern recognition in a derived part
Sam B
LinkedIn
Message 13 of 16
lena.talkhina
Hello there,
@vkulikajevas Did you find a solution? Don't hesitate to click the green button below the messgae to accept the solution.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 14 of 16
vkulikajevas
Hello @lena.talkhina ,
we came to a conclusion that this function is not available in Autodesk Inventor.
It could be as a suggestion for developers to be added in future versions of Inventor.
I work with Layouts: i.e. Make a part with many bodies and export them to assemblies (makes assembly life much more easier). But when bodies are exported there are no availability to attach pattern recognition to any of the solids. In this case, when making assembly with other sub-assemblies, with lost feature recognition, means that you have to do the same thing all over again. This function might make use of Inventor much easier.
Furthermore, apparently  this suggestion was already made in 2015 (link provided bellow, thank you @SBix26 )
https://forums.autodesk.com/t5/inventor-ideas/recognise-feature-pattern-in-derived-part-when-creatin...
Message 15 of 16
lena.talkhina
Thank you so much for the clarification @vkulikajevas !
Let's see what we can do with the idea...I will let you know if there are any changes.
Message 16 of 16
johnsonshiue
Hi Valdas,
I am not sure if you have heard about GoToInventor (https://www.iti-global.com/gotoinventor). It was developed by our partner to facilitate the process of moving from CAD X to Inventor. It supports feature based translation and maintain drawing associativity.
Many thanks!
Software Test Engineer
