New constraint violates "old" ones but there are none
I have a strange problem with a bunch of sheet metal and shrinkwrap parts in an assembly. The shrinkwraps parts were originally step files I imported from Altium designer. The problem I face is the following:
I change stuff on the PCBs, export them again as step files, import them in Inventor into an assembly and generate a new shrinkwrap part (otherwise the files are quite large and Inventor starts lagging, I guess there is too many details on the PCBs). Now when I want to update my assembly which contains PCBs and other mechanical parts Inventor complains that the shrinkwrap parts are not the same anymore and most probably all the relationships will fail. When I update the assembly, indeed most of the relationships fail (which is not really a surprise). I then delete the old constraints on the PCB parts (such that the don't have any constraint anymore, i.e. they are completely free now. I then want to set new constraints again to position the PCBs. Clicking on the respective parts moves them over the screen as the constraint preview should do. However, when I click "apply", Inventor complains that the assembly cannot be resolved. Clicking on diagnose the relationship reveals that the respective constraint conflicts with itself (see attached screenshot), clicking on "cancel" closes the window but the new constraint is now set.
Is there a reason for this? How can I get rid of this? Unfortunately I cannot publish the files.
Last: Everytime I make changes at the PCBs I have to go over all this again: importing the step file, generating shrinkwrap, redoing all the constraints. Is there more efficient way to accomplish this? Every change in the PCBs generates quite some work to reset all those things.
