Inventor Forum
Macro Parts list into Word with Thumbnail Script
5 REPLIES 5
stevenL2ZFM
1561 Views, 5 Replies
Hello all,
I have found this script to generate a parts list with a thumbnail. It places the parts list into a new word document. Is there any VBscript pro who can help me modify the code just a bit?
I am looking to change the script to open a template file instead of a blank new word document.
Script is attached as script.txt
Steven.
5 REPLIES 5
@stevenL2ZFM
I will tag @Curtis_Waguespack and he should be able to assist and/or you can post over in the Inventor Customization Forum
Mark Lancaster
Hi stevenL2ZFM,
I didn't test it, but I think something like this should work.
Replace this:
    ' Create a new Word document.
    Dim wordDoc As Word.Document
    Set wordDoc = wordApp.Application.Documents.Add
With something like this:
    sWordTemplate = "C:\Program Files\Microsoft Office" _
    & "\Templates\Memos\Professional Memo.dot"
    Set wordDoc = wordApp.Application.Documents.Add(Template:=sWordTemplate)
Source:
https://msdn.microsoft.com/en-us/library/office/ff845011.aspx
Also as Mark.Lancaster mentioned Also just as a tip, you can search and ask programming questions of this type are best placed on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
I wasn't able to get it to work... maybe my coding skills are too elementary 😄
Try this. If it's truly .vbs, you can't declare any complicated object types beyond the basic ones.
    Dim wordDoc
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for the reply. This is not working either.
But i found a new problem with the add-in 😞  After running the add-in, all fields within the parts list become static values and not associated with the part referenced.
There were two versions of this code from the website I found it on.
http://modthemachine.typepad.com/my_weblog/2010/02/parts-list-with-thumbnail-image.html
One installs as an add-in (which works but has the problem listed above)
The other is copied then pasted into a module. It worked a few times, then it just stopped working and has a compiling error (see screenshot error.jpg).
Maybe the error is a quick fix and I can try to implement the template coding you provided?
Thanks for the help !
Steven
