Get scale, format for idw Visual Basic
Im trying to find out the parameters that stands for the view scale and format in a idw. I cannot find the parameter for the view scale. Anyone any idea?
I use Visual Basic. Code for get mass is easy ...
mass = oDoc1.ComponentDefinition.MassProperties.Mass()
What about view scale if idw and format?
Gregor
Rob67ert
I use this:
SyntaxEditor Code Snippet
'ViewScale
Dim odrawdoc As DrawingDocument = ThisDoc.Document
customPropertySet = odrawdoc.PropertySets.Item("Inventor User Defined Properties")
For i = 1 To odrawdoc.Sheets.Count
Try
    prop = customPropertySet.Item("Scale" + Str(i))
Catch
    customPropertySet.Add("", "Scale" + Str(i))
End Try
Try
    iProperties.Value("Custom", "Scale" + Str(i)) = odrawdoc.sheets.item(i).DrawingViews.Item(1).ScaleString
Catch
End Try
Next i
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Mr. Robert, thanks for reply, but I had already tried that, and not working.
But I found solution,
 For Each oDrgView In oDrgViews
                    Dim scl As Double
                    scl = oDrgView.Scale
                    Dim oRefFileDesc As ReferencedFileDescriptor
                    oRefFileDesc = oDrgView.ReferencedFile
                    If (TypeOf oRefFileDesc.ReferencedDocument Is PartDocument) Then
                        Dim oPartDoc As PartDocument
                        oPartDoc = oRefFileDesc.ReferencedDocument
                    ElseIf (TypeOf oRefFileDesc.ReferencedDocument Is AssemblyDocument) Then
                        Dim oAsmDoc As AssemblyDocument
                        oAsmDoc = oRefFileDesc.ReferencedDocument
                    Else
                        Dim oPresDoc As PresentationDocument
                        oPresDoc = oRefFileDesc.ReferencedDocument
that works,
Now I don't know how to get FORMAT from idw.
Curtis_Waguespack
Hi gregor.rihtar,
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I'll ask the forum Admin to move this topic the correct forum.
I hope this helps.
Curtis
MechMachineMan
What "format" are you talking about/ wanting to get from the drawing?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for reply.
I solved that problem too.
I will share, maybe someone need it too.
merilo = "1 : " + (1 / scl).ToString
sheet_size = oSheet.Size.ToString
sheet_size ... format (A4, A3 ...)
merilo (1:5 ...)
