I am trying to create a loft feature between several sketches. When I select the last sketch, the loft rails attach to it asymmetrically. See file.
I am in Inventor Professional 2020.
Are you attempting to follow some Tutorial?
You are going to have to use Surface modeling techniques.
There are several improvements that you can use as well that I can explain if you continue the discussion.
Notice if you leave out the internal geometry from your profiles that you can Loft as a solid and then add those features later.
You could also adjust Point Mapping, but I am going to suggest that you not do that.
Another option that can work for you is... if you almost finished the model and invested a lot of time on it, instead of restarting from scratch to do the "half a boat method", maybe you can use the split tool to eliminate the half you don't like and mirror the remaining one.
Next time you start a similar symmetric model, remember that awesome tip that @SBix26 suggested.
