Inventor Forum
Loft rails not symmetric
3 REPLIES 3
grant_maiorana
285 Views, 3 Replies
grant_maiorana
Observer
Observer
I am trying to create a loft feature between several sketches. When I select the last sketch, the loft rails attach to it asymmetrically. See file.
 I am in Inventor Professional 2020.
3 REPLIES 3
JDMather
in reply to: grant_maiorana
JDMather
@grant_maiorana
Are you attempting to follow some Tutorial?
You are going to have to use Surface modeling techniques.
There are several improvements that you can use as well that I can explain if you continue the discussion.
Notice if you leave out the internal geometry from your profiles that you can Loft as a solid and then add those features later.
You could also adjust Point Mapping, but I am going to suggest that you not do that.
@grant_maiorana
SBix26
SBix26
In addition to what @JDMather suggested, I would create only half of this shape, then mirror the entire solid body.  That guarantees the the two sides are symmetric, and is also considerably less work.
Sam B
Inventor Pro 2024.0.1 | Windows 10 Home 22H2
Sam B
CCarreiras
in reply to: SBix26
CCarreiras
Another option that can work for you is... if you almost finished the model and invested a lot of time on it, instead of restarting from scratch to do the "half a boat method", maybe you can use the split tool to eliminate the half you don't like and mirror the remaining one.
Next time you start a similar symmetric model, remember that awesome tip that @SBix26 suggested.
CCarreiras
CCarreiras
