Hello guys!
Here is what i would like to do. From a part file i want to isolate one solid body and save it in another part file.
How can this be done?
Thank you!
Solved by JDMather. Go to Solution.
Solved by Gabriel_Watson. Go to Solution.
Make part command?
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-t...
If your other part already exists, you may try instead the derive command on the other part, then select only the solids you need.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Manage tab> Make Part.
Attach your file here if you can't figure it out.
