Inventor Forum
Isolate part from part
4 REPLIES 4
labrakis6JLPE
422 Views, 4 Replies
labrakis6JLPE
Hello guys!
Here is what i would like to do. From a part file i want to isolate one solid body and save it in another part file.
How can this be done?
Thank you!
Hello guys!
Thank you!
4 REPLIES 4
Gabriel_Watson
Make part command?
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-t...
If your other part already exists, you may try instead the derive command on the other part, then select only the solids you need.
Make part command?
JDMather
in reply to: labrakis6JLPE
JDMather
Manage tab> Make Part.
Attach your file here if you can't figure it out.
labrakis6JLPE
Thank you so much!! I did it!!
labrakis6JLPE
in reply to: JDMather
labrakis6JLPE
That was it!
That was it!
