Hello guys!
Here is what i would like to do. From a part file i want to isolate one solid body and save it in another part file.
How can this be done?
Thank you!
Hello guys!
Thank you!
Solved by JDMather. Go to Solution.
Solved by Gabriel_Watson. Go to Solution.
Make part command?
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-t...
If your other part already exists, you may try instead the derive command on the other part, then select only the solids you need.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Make part command?
Manage tab> Make Part.
Attach your file here if you can't figure it out.
Thank you so much!! I did it!!
