Inventor Forum
Inventor parts are darker.
8 REPLIES 8
Message 1 of 9
1255 Views, 8 Replies
New and old .ipt's appear darker all of a sudden.  I haven't changed any settings or changed material, it just... happened.  I attached a screenshot and an example .ipt
8 REPLIES 8
Message 2 of 9
admaiora
I see it correctly. What IBL do you have? (View>Appearance>IBL list
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 9
Cadmanto
Your part came in normal for me as well.
Are you using a different Project file?  Maybe is switched on you and caused this?
Did someone else in your department modify the material library and appearances by chance and didn't tell you? 😄
You can always go to the solid body and remove all appearances and change it to what you want.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 9
mcgyvr
Start by selecting a different lighting style.. Did that help?
Looks like someone may have dropped the "exposure" setting for "Light Them IBL".
Message 5 of 9
in reply to: Cadmanto
I haven't changed project files, Material is 'Generic', Appearance is 'Default', no one else uses my laptop.  Thanks for trying 😃
Message 6 of 9
in reply to: mcgyvr
Changing the light theme does make a positive difference.   I tried changing the exposure setting for Light Theme IBL, no change.  Might just have to default to a different lighting style.  Thanks for the help!
Message 7 of 9
johnsonshiue
Hi! This may also be related to Hardware setting. What is it set to (Tools -> App Options -> Hardware)?
Many thanks!
Software Test Engineer
Message 8 of 9
230roblittle
I have the same problem.  It occurs after my computer wakes up from sleep mode.  I have to close Inventor and re-open then the color is back to normal.  Autodesk said this must be a video/computer problem.  I doubt it as my 1-year-old $8k CAD workstation has 16GB of video memory and all the updates.
Message 9 of 9
johnsonshiue
Hi! It should be lighting style related. Could you take a screenshot when it happens next time? Also, what is the Hardware setting (Tools -> App Options -> Hardware)?
Many thanks!
Technology Administrators
