I see it correctly. What IBL do you have? (View>Appearance>IBL list
Admaiora
Your part came in normal for me as well.
Are you using a different Project file? Maybe is switched on you and caused this?
Did someone else in your department modify the material library and appearances by chance and didn't tell you? 😄
You can always go to the solid body and remove all appearances and change it to what you want.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Start by selecting a different lighting style.. Did that help?
Looks like someone may have dropped the "exposure" setting for "Light Them IBL".
I haven't changed project files, Material is 'Generic', Appearance is 'Default', no one else uses my laptop. Thanks for trying 😃
Changing the light theme does make a positive difference. I tried changing the exposure setting for Light Theme IBL, no change. Might just have to default to a different lighting style. Thanks for the help!
Hi! This may also be related to Hardware setting. What is it set to (Tools -> App Options -> Hardware)?
Many thanks!
I have the same problem. It occurs after my computer wakes up from sleep mode. I have to close Inventor and re-open then the color is back to normal. Autodesk said this must be a video/computer problem. I doubt it as my 1-year-old $8k CAD workstation has 16GB of video memory and all the updates.
Hi! It should be lighting style related. Could you take a screenshot when it happens next time? Also, what is the Hardware setting (Tools -> App Options -> Hardware)?
Many thanks!
