Inventor 2016 Update 2 NOT SHOWING AS INSTALLED
Paul-Mason
Message 1 of 10
Paul-Mason
I've down loaded and according to all the mesages Update 2 has been installed
BUT on that About scareen
This despite a cold reboot and several attempts to install the update.
Is/has anyone else having/had the same problem
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
Replies (9)
Message 2 of 10
MechMachineMan
Back when we were using 2014 it always had this issue too; I think the update was actually installed, it would just never update in the about window..
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 10
Paul-Mason
It could possibly be a similar problem here, I had a similar problem with update one not showing as installed for some time, well until I did maintenance reinstall from control Panel. I thin I'll try a maintenance reinstall and see if that fixed it.
Inventor 2026 Pro
Xeon
Message 4 of 10
blair
I just check the Windows>Control Panel>Programs and Features>Show Installed Updates.
It used to show the updates in the "About" Panel. I think it changed a number of releases ago.
Delta Tau Chi ΔΤΧ
Message 5 of 10
Paul-Mason
On Win 7 Pro it veiw update on the LH side, anyhow after clciling on that I'm NOT seening Update 2 as installed :-
Strange that 2015 is still showing as it was un-installed when I installed 2016, so those updates should not be showing as installed.
Inventor 2026 Pro
Xeon
Message 6 of 10
DarrenP
Mine shows up Inventor 2016
also shows up in Add/Remove features
so something else is happening
DarrenP
Message 7 of 10
Paul-Mason
So I eventually got this sorted, by un-installing, rebooting and re-installing the main Inventor program, run once close down, MANUALLY installed the update, now showing as installed, WHAT A MUCK AROUND, I THINK this is exactly what I did with update 1
Inventor 2026 Pro
Xeon
Message 8 of 10
ChrisMitchell01
Hi Paul,
Good to hear that you got it sorted, but it obviously shouldn't be that difficult. Where did you initially install Inventor from ? A standalone installer on USB, a download, or a specific Suite ?
I know that the initial Building Design Suite release included the wrong release version of Inventor, hence my questions.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 9 of 10
Paul-Mason
Originally form a download saved to my "E" drive. But not installed until a few months after release.
Inventor 2026 Pro
Xeon
Message 10 of 10
ChrisMitchell01
Ok - what was that download ? Just Inventor or a Suite ?
Chris Mitchell
Autodesk, Inc.
