Inventor Forum
Inv 2014 on xp
8 REPLIES 8
Message 1 of 9
ferrisb
1582 Views, 8 Replies
Inv 2014 on xp
Is it possible to install Inv 2014 on Windows xp Prof 64bit?
8 REPLIES 8
Message 2 of 9
samiharada
in reply to: ferrisb
No, it's not possible.
Thank you,
-Sami Harada
Inventor Framework QA
Autodesk, Inc.
Message 3 of 9
Cadmanto
If you look at the recommended system specs from the Autodesk website, 2013 was the last year that XP was supported.  It is not listed in the 2014 specs.  My guess is it might load and might run, but it would be dog slow.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 9
ferrisb
in reply to: Cadmanto
Yes I looked at the system requirments, but the guy who ordered the upgrade did not, lol.
Message 5 of 9
DarrenP
here is the unsupported method
Open Setup.ini, find "Custom Callback" group near the top and remove the "XP_64;" then save the file and proceed with installation.
not guranteed to work, may cause stability issues
DarrenP
Message 6 of 9
ic198
in reply to: DarrenP
Our vault server is on a machine running XP- which means I can't upgrade Vault, so I can't move to Inventor 2014 either. Darren, will your fix work for installing Vault server as well?
Message 7 of 9
DarrenP
in reply to: ic198
i can't gurantee it
DarrenP
Message 8 of 9
ic198
Fair enough! Not sure I want to take that risk with the Vault server- not particularly looking forward to telling my boss we need a new server either though... 😉
Thanks for the reply
Message 9 of 9
DarrenP
in reply to: ic198
i looked through a vault pro 2014 setup.ini and i don't see this line in there
this won't work with vault pro 2014
this may work if your installing Vault from the Product Design suite 2014 this line is in the setup.ini
but not guranteed
DarrenP
