No, it's not possible.
Thank you,
-Sami Harada
Inventor Framework QA
Autodesk, Inc.
If you look at the recommended system specs from the Autodesk website, 2013 was the last year that XP was supported. It is not listed in the 2014 specs. My guess is it might load and might run, but it would be dog slow.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
here is the unsupported method
Open Setup.ini, find "Custom Callback" group near the top and remove the "XP_64;" then save the file and proceed with installation.
not guranteed to work, may cause stability issues
DarrenP
Our vault server is on a machine running XP- which means I can't upgrade Vault, so I can't move to Inventor 2014 either. Darren, will your fix work for installing Vault server as well?
i can't gurantee it
DarrenP
Fair enough! Not sure I want to take that risk with the Vault server- not particularly looking forward to telling my boss we need a new server either though... 😉
Thanks for the reply
i looked through a vault pro 2014 setup.ini and i don't see this line in there
this won't work with vault pro 2014
this may work if your installing Vault from the Product Design suite 2014 this line is in the setup.ini
but not guranteed
DarrenP
