Inventor Forum
iMate
3 REPLIES 3
Rob67ert
201 Views, 3 Replies
iMate
I hope i'm doing something wrong and someone can help me.
When I place the Steen.ipt in the assembly Stenen.iam and use the "Automatically generate iMates on Place" the first Steen goes correct.
I like to have face 2 flush with 2, 4 flush with 4 and 1 and 6 towards each other.
Now when I place a third Steen there will only be one iMate, the fourth will be connected correct to the third.
How can I fix this that all the parts will be on top of each other?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
3 REPLIES 3
blandb
in reply to: Rob67ert
I'm not sure if I follow you, if you use the up/down/left/right arrows on keyboard you can get them to flip around.  Does that do what you want it to?
Autodesk Certified Professional
johnsonshiue
Hi Robert,
I am not sure I am seeing the undesirable behavior. Here is what I did.
1) Open Stenen.iam
2) Place Steen once.
3) Keep clicking left mouse button at graphics window. It cycles through the remaining iMate and continue to next occurrence.
The dice keeps stacking up.
Is this not what you are seeing?
Many thanks!
Software Test Engineer
Rob67ert
in reply to: johnsonshiue
Yes that's what I want.
But the third is not complete fixed to the second.
I like them to be fixed like the first and second.
Robert
