Hello all,
I am folding a part in the sheet metal enviornment, an 8" x 12" rectangle with 6 c'bore'd holes in the face. When I fold it right in the middle it actually pops the counterbored holes thru the part instead of folding it with the part. Not sure what I am doing wrong, but any help would be fantastico!
TIA! 🙂
Maybe something like this (see attached).
TCW, I am honestly not sure what you mean by as-bent? Are you meaning to draw it bent and dimension each hole along the curve so it properly cuts?
JD, the part looks great even if I am completely lost with how you did it. My sheet metal environment knowledge is somewhat limited due to lack of use at this time. But thank you 🙂 I will compare to the manufactures specs and see how she looks.
Appreciate it fellows!
Forget you ever saw the Fold tool - it is almost always the incorrect tool to use (especially for a beginner).
Hi Randy,
Fold command assumes the bend zone is always cylindrical face without any deformation. It cannot handle cutouts or holes in the bend zone. To drill the holes, you will need to unfold it so you get the flat piece. Then drill the hole and refold it back. Please take a look at the attached file. I did not fix up the sick sketch. This is just showing you how to do that.
Many thanks!
