Inventor Forum
Welcome to Autodeskโ€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Sheet Metal Fold
5 REPLIES 5
Talayoe
419 Views, 5 Replies
Sheet Metal Fold
Talayoe
Hello all,
I am folding a part in the sheet metal enviornment, an 8" x 12" rectangle with 6 c'bore'd holes in the face. When I fold it right in the middle it actually pops the counterbored holes thru the part instead of folding it with the part. Not sure what I am doing wrong, but any help would be fantastico!
TIA! ๐Ÿ™‚
-Randy
Inventor 2017 PDS
Sheet Metal Fold
Hello all,
TIA! ๐Ÿ™‚
-Randy
Inventor 2017 PDS
5 REPLIES 5
TheCADWhisperer
in reply to: Talayoe
TheCADWhisperer
@Talayoe wrote:
.... Not sure what I am doing wrong,
Can you create the part in "as-bent" state and avoid Extrude and Fold commands?
Your Fold forms an angle of 32.068533310
is that what you really want?
JDMather
JDMather
Maybe something like this (see attached).
Talayoe
in reply to: JDMather
Talayoe
TCW, I am honestly not sure what you mean by as-bent? Are you meaning to draw it bent and dimension each hole along the curve so it properly cuts?
JD, the part looks great even if I am completely lost with how you did it. My sheet metal environment knowledge is somewhat limited due to lack of use at this time. But thank you ๐Ÿ™‚ I will compare to the manufactures specs and see how she looks.
Appreciate it fellows!
-Randy
Inventor 2017 PDS
-Randy
Inventor 2017 PDS
JDMather
JDMather
Forget you ever saw the Fold tool - it is almost always the incorrect tool to use (especially for a beginner).
johnsonshiue
johnsonshiue
Hi Randy,
Fold command assumes the bend zone is always cylindrical face without any deformation. It cannot handle cutouts or holes in the bend zone. To drill the holes, you will need to unfold it so you get the flat piece. Then drill the hole and refold it back. Please take a look at the attached file. I did not fix up the sick sketch. This is just showing you how to do that.
Many thanks!
Software Test Engineer
Hi Randy,
Many thanks!
