Image File in Title Block Template
dbyrdJKJBQ
Message 1 of 11
dbyrdJKJBQ
I'm having an issue with my title block template. There is an image associated with the title block but it is not actually used in the template itself. It is not causing me any issues but I'd really like to get rid of it. The only place I can see it is in the Vault tab under "3rd Party". I am attaching a screen cap of what it looks like. Can anyone help me get rid of this?
Replies (10)
Message 2 of 11
mcgyvr
Try this..
  1. Stand on your left foot..
  2. Check the file out of Vault
  3. Go to the "Tools" tab and in the "options" section press the "Links" button
  4. Select the image and "Break" the link
  5. Switch to standing on your right foot and grab your right ear lobe.
  6. In the Inventor vault browser and press the "Refresh Vault Status" button.
  7. Check it back into Vault
Good?
Message 3 of 11
dbyrdJKJBQ
I actually already tried this minus standing on my left foot, maybe that's where it went wrong haha.
Message 4 of 11
Chancellor.Kurre
Instructions unclear. Stuck standing on right foot and holding earlobe 😁
Message 5 of 11
bradeneuropeArthur
What happens if you do the same, but after you have "Saved as" the drawing without checking it into Vault?
Is it then deleted and away?
@dbyrdJKJBQ
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 6 of 11
johnsonshiue
Hi! Open the drawing file and go to Tools -> Link -> break link.
Many thanks!
Software Test Engineer
Message 7 of 11
dbyrdJKJBQ
Unfortunately this did not work either.
Message 8 of 11
dbyrdJKJBQ
Here is another screen cap of the Links page. The top choice is the only one that will let me click break link, but even after doing so upon reopening the links page everything is still shown and the break link button is not grayed out like the bottom choice here.
Message 9 of 11
bradeneuropeArthur
Also not with save copy as and activate the copy?
Try export to idw.
Then export to dwg again or vice versa.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 11
bradeneuropeArthur
https://forums.autodesk.com/t5/inventor-forum/need-to-delete-a-third-party-image-file-link/m-p/34972...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 11
dbyrdJKJBQ
Nothing suggested has worked, I just created a new title block. Thank you all anyway.
