iLogic window lost
iLogic window lost
Nsteel
Message 1 of 21
iLogic window lost
Nsteel
For whatever reason my iLogic browser pane has vanished.
I've have never had dual screens, I've already tried deleting the registry entry (as per http://discussion.autodesk.com/thread.jspa?messageID=5497535) and using the inventor reset utility. No luck, and there is no check box under view/user interface for ilogic anymore.
I've used every version of Inventor from 2013 to 2018, and they only seem to get more and more unreliable.
Can anyone offer any other methods of resolving this?
Ta,
Inventor 2018 Pro 64 Bit
Build 171, Release 2018.1.1
Replies (20)
Message 2 of 21
MechMachineMan
Tools > Options > Add-ins.
Ensure the boxes are checked/unchecked correctly to ensure the add-in is loaded, and that it loads automatically.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 21
Nsteel
The load/unload box is greyed out as checked.
All I can do here is check/uncheck the load automatically box.
Message 4 of 21
doug.johnston
Try this:
Manage Tab
iLogic section
click on "Ilogic Browser"
It's not easy maintaining this level of insanity !!!!!
Message 5 of 21
Nsteel
Yep, tried that too.
Message 6 of 21
Thomas_Savage
Hello @Nsteel
Does the method in my screencast allow you to get your iLogic browser back?
Thomas.
Thomas Savage
Design Engineer
Message 7 of 21
johnsonshiue
Hi! I guess you may want to try using Inventor Reset Utility (All Programs -> Autodesk -> Autodesk Inventor Professional 2018 -> Tools -> Inventor Reset Utility).
Many thanks!
Software Test Engineer
Message 8 of 21
Nsteel
@Thomas_Savage  thanks for taking the time to do that, unfortunately it doesn't help, the button does not do anything.
@johnsonshiue as per my first post, I've already tried that.
Message 9 of 21
Rob67ert
Could it be it is simple just of your screen?
Turn off the iLogic menu, turn it on and then use "alt" "space" and choose m for move.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 10 of 21
Thomas_Savage
As @Rob67ert said, it is just off the screen?
I was thinking this, as that is why the iLogic browser button is doing nothing, because it is already there, just where you can't see it.
Thomas.
Thomas Savage
Design Engineer
Message 11 of 21
Nsteel
@Thomas_Savage
@Rob67ert
I can see where you were going with this, unfortunately this does not work, it keeps selecting the main inventor window, I'm putting this down to the ilogic browser being a pane in Inventor rather than a pop up window.
 Thanks for the suggestions though.
Message 12 of 21
andrewiv
If you click on the plus sign to show tabs on your browser do you get the iLogic option?  If not then it is definitely coming up off the screen and it does not behave like other windows with the Alt+Space+M command.  I thought that you used to be able to click on the iLogic Browser button and it would hide the browser, but it doesn't do that in 2018.  I only mention this because if you could hide the browser then it would appear when you click the plus sign on the browser tabs.
Andrew In’t Veld
Designer / CAD Administrator
Message 13 of 21
Nsteel
iLogic does not appear in the drop down when I click the + sign.
I wrote this snippet of code to see if I could find and manipulate the ilogic window via an Add-in, but it does not find it either;
Dim oDoc As Document
        oDoc = InvApp.ActiveDocument
        Dim oPane As BrowserPane
        Dim oPanes As BrowserPanes
        oPanes = oDoc.BrowserPanes
        For Each oPane In oPanes
            MsgBox(oPane.Name)
        Next
Message 14 of 21
andrewiv
Do you have the ability to connect a second monitor temporarily to see if the iLogic browser appears and move it to the main monitor?
Andrew In’t Veld
Message 15 of 21
kelly.young
Autodesk Support
Autodesk Support
Hello @Nsteel something similar happened a while ago but that was the ribbon bar, not the iLogic window. Does this link help?
Missing Top Line Panel/Menu, Hidden Ribbon Bar
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 16 of 21
kelly.young
Autodesk Support
Autodesk Support
@Nsteel did you find the window? Was the ribbon reset shown in the screencast link helpful?
Can you post a screenshot of your full Inventor window to see what the behavior looks like?
Message 17 of 21
Nsteel
Hi. Sorry, I’ve not been in the office to test out the multi screen thing.
What I did notice (for what it’s worth) is that when starting inventor as it boots the illogic window appears in the top left corner of the window but is not selectable.
I will pester the it dept to lend me a monitor next week.
Message 18 of 21
kelly.young
Autodesk Support
Autodesk Support
@Nsteel hit Ctrl + PrintScreen and paste Ctrl+V into a paint document and post the screenshot back here.
What you are explaining is hard to visualize as it is not normal. If you can share what you are seeing we can help.
Message 19 of 21
Nsteel
Go figure,
I come back in after the weekend, start up inventor and there's the ilogic window back as if nothing happened.
have restarted the machine several times over the last week so don't know why it suddenly decided to start behaving now.
I kow this isn't much of a soluction, but big thanks to everyone for their help.
Message 20 of 21
llorden4
Having had this little battle myself on why the iLogic option is completely disappearing from my ribbon bar...
I have discovered that if you're using a Windows File browser and double click on an Inventor file to open it, then opening the file in that method makes the iLogic floating menu AND ribbon bar option disappear from Inventor.
Autodesk Inventor Certified Professional
