Missing Top Line Panel/Menu, Hidden Ribbon Bar
raymondsmith
Message 1 of 18
raymondsmith
OK, I have gone and done it.  Some how I have turned off the top of the line menu/panels for Inventor 2016.  All the literature says to right-click but there is no area in which to right click.  Is there a key stroke function that will make the top of the line menu/panels re-appear?
kelly.young has edited your subject line for clarity: Missing Top Line Panel/Menu
Replies (17)
Message 2 of 18
Thomas_Savage
The screencast shows the button which you need to click to get your menu/panels back.
If this is the menu/panels which are missing?
Hope this helps?
Thomas.
Thomas Savage
Design Engineer
Message 3 of 18
raymondsmith
Thank you for the help.
What if I only have the Quick Access Tool bar?
Message 4 of 18
mcgyvr
@raymondsmith Don't think thats possible unless you are having a graphics card driver issue?
It should be that "pill" button they are showing in the video above
Have you updated your graphics card driver to the latest version from the card manufacturers site?
How about restarting your computer?
Message 5 of 18
kelly.young
Autodesk Support
Autodesk Support
Hello @raymondsmith I am checking back to see if any of the replies helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Select the Accept as Solution button if a post or posts solves your issue or answers your question.
Message 6 of 18
kelly.young
Autodesk Support
Autodesk Support
@raymondsmith here is a bit more information that might help you with your issue.
How to use Inventor Reset Utility to reset the local environment for a Windows User Account (Invento...
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 7 of 18
raymondsmith
all I have is the Quick Access Toolbar and nothing else.  Are there keystokes to recall the other toolbars?
Message 8 of 18
kelly.young
Autodesk Support
Autodesk Support
Hello @raymondsmith you can press the Alt key and it will bring up the hotkeys associated with the ribbon. For instance you can then press 'X' then '2'
You can customize the Quick Access Toolbar here if you need to.
Message 9 of 18
raymondsmith
I still can't bring up the top of the line Ribbon or Toolbars.
Message 10 of 18
kelly.young
Autodesk Support
Autodesk Support
@raymondsmith can you post a quick screenshot so we can see what you are experiencing?
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories select the Snipping Tool
or
Ctrl + PrintScreen, open Paint, Ctrl + V (paste)
Message 11 of 18
raymondsmith
Attached is what I am seeing.
Message 12 of 18
kelly.young
Autodesk Support
Autodesk Support
@raymondsmith please try to attach your image again, thanks.
Message 13 of 18
raymondsmith
see attached
Message 14 of 18
kelly.young
Autodesk Support
Autodesk Support
@raymondsmith after a bit of trial and error I was able to reproduce your screen by unplugging my second monitor.
The Ribbon Bar is unattached and floating in space where the second monitor used to be. I tried changing a bunch of settings but nothing worked.
You will not see anything going on but it should bring the ribbon bar back if you follow these steps:
ALT
M
DOCUMENT KEY (BETWEEN Ctrl + Windows)
DOWN ARROW
RIGHT ARROW
UP ARROW
ENTER
ENTER
Message 15 of 18
raymondsmith
I do not have a document key on my keyboard. ctrl-Fn-Windows-alt keys
When I view the Display setting, they show only on monitor with single
view.
Message 16 of 18
kelly.young
Autodesk Support
Autodesk Support
@raymondsmith Even when changed to single view the ribbon is still floating in space, I tried that on my computer. If you hooked up a second monitor you would probably see it. You can always run the reset utility if you are getting frustrated, but before you do, try this:
ALT
M
Shift + F10 (on Laptop)    or   MENU KEY (Between Ctrl + Windows on Keyboard)
DOWN ARROW
RIGHT ARROW
UP ARROW
ENTER
ENTER
Message 17 of 18
trevorauman
This partially resolved the problem, but only after we modified the positions of the dual monitors. The monitors had been set up as stacked one on top of the other, so even with both monitors showing the ribbon was still missing. We tried the positions of the monitors in a few different positions to finally find the ribbon bar.
Message 18 of 18
twicks
Amazing help!  Thanks so much.  This happened to me on about 2020-OCT-01 and this key sequence fixed it.  I am using two monitors through a VPN.  The actual Thinkstation shows the ribbon, but the remote VPN did not.  Now it does.
Thanks!
