Inventor Forum
iLogic - Naming solid bodies with dropdown list as a standard name
9 REPLIES 9
Message 1 of 10
2388 Views, 9 Replies
Hi Everyone
This is my first post and I have a tricky request.
Can someone help to achieve the renaming of solid bodies by array list - click on the solid body and rename by a pre-defined name list (dropdownlist) from excel or text document?
This is a mix from the post:
http://inventortrenches.blogspot.ae/2012/02/ilogic-to-rename-all-solid-bodies.html
and
http://inventortrenches.blogspot.ae/2013/07/ilogic-add-standard-virtual-parts-from.html
and
http://inventortrenches.blogspot.ae/2013/01/ilogic-solid-body-visibility.html
The main idea is to always assure same part names when making components for example for furniture like TOP PANEL or RIGHT PANEL and this in an easy way to avoid writing always over and over again same naming.
Your input and ideas are well appreciated.
9 REPLIES 9
Message 2 of 10
MechMachineMan
Here is an iLogic solution.
To be ran from the part file.
Add extra names by just adding more lines of oList.Add, following the current format.
It runs in a loop until you hit escape during selection or use the exit button during list box.
Sub Main()
	Dim oList As New List(Of String)
	oList.Add("Top")
	oList.Add("Right Panel")
	Do
		oBody = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Pick Body to Rename")
		If oBody Is Nothing
			GoTo ExitSelectLoop
		End If
		oName = InputListBox("Select the name for this body", oList)
If oName <> "" Then oBody.Name = oName
Else
GoTo ExitSelectLoop
End if Loop ExitSelectLoop: End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 10
in reply to: MechMachineMan
.... you guys rock!
I tested it and is exactly what I am looking for - awesome and well done.
Wich I would have the knowledge you guys have - but working on it.
Thanks for your support!
Message 4 of 10
Not sure if this is the best place to post this follow-on request, but seems to be the latest thread referencing this rule:
I have been trying to add a simple If /Then condition to this rule so that it will only rename bodies in a multi-body part that are marked for export (or, alternatively, only bodies that are visible).  Often I have bodies in a multi-body part that will not make the cut to be a part in the assembly for which I am making components, and therefore I would like the rule to skip these bodies when numbering in sequence so the resulting assembly does not have gaps in part numbers.  I have also tried to make the skipping behavior contingent on body visibility, but always get an error with my code (which I’m sure is just totally incorrect).  Any thoughts?  Seems like this should be an easy one for you guys.
Thanks in advance for any help.
Message 5 of 10
MechMachineMan
@Anonymous You probably would have been better making a new thread.
 However, based on the code in your supplied link
and using the API help to figure out the available calls:
(found here: http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-F20C9F1B-2BB1-4B7E-BA3E-FF1731F9F0DA)
The modified code should look something like this:
'check for custom iProperty and add it if not found
Dim prefix As String = "Prefix"
customPropertySet = ThisDoc.Document.PropertySets.Item _
("Inventor User Defined Properties")
Try
         prop= customPropertySet.Item(prefix)
Catch
      ' Assume error means not found
            customPropertySet.Add("", prefix)
End Try
'write the part number to the Prefix iProperty if it is empty
if iProperties.Value("Custom", "Prefix") = "" Then
iProperties.Value("Custom", "Prefix") = iProperties.Value("Project", "Part Number") & "_"
else
end if
'check that this active document is a part file
Dim partDoc As PartDocument
If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
MessageBox.Show ("Please open a part document", "iLogic")
End If
'define the active document
partDoc = ThisApplication.ActiveDocument
Dim solid As SurfaceBody
Dim i As Integer
'get input from user
prefix = InputBox("Enter a prefix for the solid body names", "iLogic", iProperties.Value("Custom", "Prefix"))
'write input back to custom iProperty
iProperties.Value("Custom", "Prefix") = prefix
i = 1
'renam
e all solid bodies incrementing suffix For Each solid In partDoc.ComponentDefinition.SurfaceBodies
If solid.Exported = True solid.Name = prefix + IIf(i < 10, "0" + CStr(i), CStr(i))
end if
i = i + 1 Next
Justin K
Message 6 of 10
Message 7 of 10
Hi All,
The supplied code works great, however as was previously mentioned is there a way
to only rename visible solids in this manner?
Or alternately is there a way to rename only selected solids
potentially using pick?
Let me know what you think
Regards
Bruce
Message 8 of 10
MechMachineMan
@Anonymous
Yes. Move the
i = i + 1
line inside of the If statement that controls the processing criteria.
ie; move it up 2 lines above the "End If".
Justin K
Message 9 of 10
@bruce.blundell
Sure. Use the appropriate call available on the solid object with an appropriate "If" statement to cause the rule to process as you require. (Much the like If solid.Exported = True, except more like "If solid.Visible = true")
Alternatively, you can search around more on the forums to find code that would process a "select set" (which is better than pick functionality in this case) and figure out how to modify the code to use that as a criteria instead of the "if" statements.
Justin K
Message 10 of 10
Perfect that's great, works a treat
Technology Administrators
