iLogic: measure time elapsed during run rule
I have a (simple?) question.
I have made a tool to design a product. But i'm wondering if i can measure the time it needs to run a certain rule.
Greetings
And have a nice weekend!
MechMachineMan
https://msdn.microsoft.com/en-us/library/system.timers.timer_methods(v=vs.110).aspx
So something like this, with necessary imports:
Public Class Form2
Private _elapseTimerRunning As Boolean = False
Private _elapseStartTime As DateTime
Private Sub Form2_Load(sender As Object, e As EventArgs) Handles Me.Load
    Timer1.Interval = 1000    Timer1.Enabled = True
End Sub
Private Sub Timer1_Tick(sender As Object, e As EventArgs) Handles Timer1.Tick
    txtTime.Text = Now.ToString("h:mm:ss tt")
    If _elapseTimerRunning = True Then
        Dim elapsedtime = DateTime.Now.Subtract(_elapseStartTime)        txtElapsed.Text = String.Format("{0}hr : {1}min : {2}sec", elapsedtime.Hours, elapsedtime.Minutes, elapsedtime.Seconds)
    End If
End Sub
Private Sub btnStart_Click(sender As Object, e As EventArgs) Handles btnStart.Click
    _elapseStartTime = DateTime.Now
End Sub
Private Sub btnStop_Click(sender As Object, e As EventArgs) Handles btnStop.Click
    _elapseTimerRunning = False
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
MechMachineMan
Sorry, even better would be:
Imports System
Imports System.Diagnostics
Imports System.Threading
Class Program
Shared Sub Main(ByVal args() As String)
Dim stopWatch As New Stopwatch()
stopWatch.Start()
Thread.Sleep(10000)
stopWatch.Stop()
' Get the elapsed time as a TimeSpan value.
Dim ts As TimeSpan = stopWatch.Elapsed
' Format and display the TimeSpan value.
Dim elapsedTime As String = String.Format("{0:00}:{1:00}:{2:00}.{3:00}", ts.Hours, ts.Minutes, ts.Seconds, ts.Milliseconds / 10)
Console.WriteLine( "RunTime " + elapsedTime)
End Sub 'Main
End Class 'Program
Justin K
MechMachineMan
Fully working in Inventor so you can test yourself (I have tested it)
Imports System
Sub Main
	stopWatch.Start()
	MsgBox("Hit OK to end timer")
	stopWatch.Stop()
MsgBox("RunTime " & elapsedTime)
'Console.WriteLine( "RunTime " + elapsedTime)
End Sub 'Main
Justin K
Thanks!
i used following bits 🙂 works like a charm 🙂 just tested 😉
 stopWatch.Start()
~~~~SOME CODE HERE~~~
 stopWatch.Stop()
Don't know why the imports are needed?
Cheers!
MechMachineMan
It worked for you without the imports? I have ran into issues not using
them before (I think) so I included them just in case, as I wasn't sure if
the timer class was already included in the inventor programming.
Justin K
Yes it's running just fine 🙂
just removed the subs & voila 😄
