hey how can i rotate this file? driving me crazy 😕
kelly.young has edited your subject line for clarity: how to rotate?
The MOVE BODIES feature, or the DIRECT EDIT functionality.
thanks! direct edit does not work because it consists of multiple parts. how can i select them all and rotate/move?
Just crossing window select them all.
You have to switch your selection priority from faces to solids and then you can select them all.
Andrew In’t Veld
Designer / CAD Administrator![]()
Hmm. I don't use Repair Environment in most cases.
SLDPRT came in well aligned here, in 2017
Walter Holzwarth
