hey how can i rotate this file? driving me crazy ๐
kelly.young has edited your subject line for clarity: how to rotate?
Solved by WHolzwarth. Go to Solution.
Solved by andrewiv. Go to Solution.
Solved by JDMather. Go to Solution.
The MOVE BODIES feature, or the DIRECT EDIT functionality.
thanks! direct edit does not work because it consists of multiple parts. how can i select them all and rotate/move?
Just crossing window select them all.
You have to switch your selection priority from faces to solids and then you can select them all.
Andrew Inโt Veld
Designer
Hmm. I don't use Repair Environment in most cases.
SLDPRT came in well aligned here, in 2017
Walter Holzwarth
