Inventor Forum
How To Rotate Imported Solids?
5 REPLIES 5
simon.weishaeupl
1765 Views, 5 Replies
hey how can i rotate this file? driving me crazy 😕
kelly.young has edited your subject line for clarity: how to rotate?
5 REPLIES 5
The MOVE BODIES feature, or the DIRECT EDIT functionality.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
thanks! direct edit does not work because it consists of multiple parts. how can i select them all and rotate/move?
JDMather
in reply to: simon.weishaeupl
Just crossing window select them all.
andrewiv
You have to switch your selection priority from faces to solids and then you can select them all.
Andrew In’t Veld
Designer
Hmm. I don't use Repair Environment in most cases.
SLDPRT came in well aligned here, in 2017
Alignment ok.jpg.
Walter Holzwarth
Technology Administrators
